JdeW
- Laarbeek The Netherlands
Today I start with a major service on my 2001 Twingo mk1 phase 3 as well as a minor service on my 2008 Honda CR-V.
Everything has arrived as seen on the picture, on the left for my small Twingo and on the right for my larger Honda CR-V.
The Twingo major service consist of;
- Timing belt replacement with tensioner.
- Waterpump replacement and new coolant.
- Replacement of two poly V-belts one with tensioner.
- Engine oil flush and fresh oil.
- New air-, oil- and fuelfilters.
- New spark plugs
Also a new speed sensor which was lying around in the shed for two years.
The timing belt replacement is a bit more extensive since my Twingo is equipped with an airco.
I'll keep you informed.
- New spark plugs
