Gents,
Here's the story so far. Rene (76 TL) running pretty good, plugs a good colour, but sooty tail pipe, around 45mpg. Opened up the little hole in the manifold where the breather pipe goes in, the one below the carb with the elbow on it, it was blocked. Car instanty runs better (it wasn't that bad before) and fuel consumption much better, pulls up hills with minimum throttle, cruises with a whiff of the throttle pedal. What I'm not sure about is having to unscrew the idle/mixture screw to almost 7 turns out to get a decent tickover, to be honest it was 5 turns out before and hunted a bit. Seems like there's more fuel getting into the inlet side of things than there should be. I've checked float hight, cleaned out the carb, no change. Ignition, timing etc all checked. Starting from cold is instant, but the choke can be shut off withing 100 yards and it runs great, suspicious!. As I said, the car has never run better. Any ideas?.
Alan.
Alan.
