STEPHEN ADDISON
- THIRSK, NORTH YORKSHIRE
Hi good afternoon, ---- I would like some clarification if possible please on the task of fitting the 5 speed box onto the Gordini engine for installation to an R4. ----- I have read a couple of times the detailed explanation in the restoration section on this subject, but I can not decide if my end conclusion is correct.
A) Paragraph one appears to say the task is to use the 5 speed box in place of the 4 speed.
B) Paragraph two then sounds like the 4 speed is to be used by adding some parts from the 5 speed.
C) Paragraph three now goes back to using the 5 speed,swapping the bell housing and clutch shaft from the R4 gaining approx. 10 mm along with the R4 gearbox top cover, enabling the dash mounted gear lever to be retained.
Reading on, I take it to understand the end result is that the engine and box are some 20 mm or so longer than standard R4, the front member then needed amending but also the bell housing needed modifying for the belt to fit properly and the bonnet had to be adjusted to fit the increased front member.
I can not decide from reading this technical piece, if you still need to use the R4 housing and shaft, or if it would not have been simpler to use the original 5 speed box housing and shaft, avoid altering for the belt and adapting the front member and bonnet to accommodate this extra 10 mm
I am not a purist for the R4 final look so I have no worries on adapting the body work for a further 10 mm ----- Can anyone advise if I am missing the point here, if so I would be very great full to be guided in the correct direction.
Steve
Steve
