Alternator
The4seeker
Yesterday my red light came on and car died.
1984 R4 GTL
Does anyone know where I can get a new one from? or even a secondhand one.
Probably I have the aternator for R4 and probably it works - but I can't guarantee it for You in 100%...I need to look into my cabinet with parts...
On tommorow evening I give You an answer.
I've got a secondhand one, but if your after a reconditioned one then you'll probably find your local motor factors will be able to either order you one in on exchange or get your own reconditioned.
I am trying to buy a new one as the car is not in England, and I do not have the opriginal unit to exchange, and as it happens I have tried my local motor factors and they have a few diffrerent trypes listed for for a 1984 GTL and not of them match my Ducellier, which is odd as I have another R4 and it has the same alternator also (not working either)!!!!
Both replacement I have found have different mountings....instead of a front and rear with a long bolt only a only at the front
If it doesn't matter what the replacement looks like, There are other brands which should fit, depending on the mounting. For example, Delco or Bosch internally-regulated high amperage units which could be had for a fraction of their new price
