Cornish4
Le Dazzleur
- Falmouth
Hi folks, I need some help please. Having fitted front fog lamps a while ago, and recently added roof mounted spots to my R4, I thought I would convert them to LED bulbs for in theory a brighter light, less load to the system and longevity.
Now fitted they are no way brighter than the filament bulbs, in fact they are dimmer.
My question is, do I need to fit a resistor in parallel with the feed to the lights to make them function correctly?
I know a resistor is required on the indicator circuit to make them flash correctly, as I found on the Twingo I once owned, but when I fitted front and rear sidelight LEDs on it they were very bright without any mods to the circuitry, as are the the brake/tail LEDs I've experimented with on the 4.
So, any info would be much appreciated, many thanks, regards Brian.
Unregulated brightness of LED bulbs that dazzle or confuse traffic? Traffic is bl88dy easy to confuse, let's face it.
