bixdog
Daily Driver
Greetings!
It's been ages since I posted, mostly because my 1988 R4 GTL has been running wonderfully for two years now.
Then she sat up for about a month in the middle of a Portugal winter, so we're talking lots of rain, but not too cold. She started up just fine, but as the thread title says, she craps out if I don't rev the engine hard, or have the choke pulled way out (which revs the engine hard). She runs fine on the highway, but dies at every traffic light. huge pain.
So I went through all the usual stuff. I've replaced the entire ignition system, except for the coil, gonna do that next, but no change with an older spare coil I had, and also the entire ignition system was replaced only two years ago.
Then I attacked the carb - did the wd40 spray, which is kind of inconclusive because I have to rev her high to keep running at all. Pulled the carb, checked and cleaned everything, seems okay. Checked the breather hoses, nothing obvious there. I had a guy come by with a carb he had for sale, whacked it on, basically the same thing - she just wont idle.
The carb mount gaskets were not in the best shape, will order new ones, but I made some improvised gaskets from gasket paper, not a long term nor high temperature solution but should at least rule out air leakage at the mount no?
Turning the mixture screw all in or all out seems to have no effect what so ever.
I just don't get it. She was running like a charm. I'm still driving her around, but only when I absolutely have to, and only when most of the drive is straight highway. So there has been plenty of new petrol run through the system as well.
I am absolutely desperate, I need this car to run! Any ideas?
Thanks,
John
Thanks,
John
