bar, joint, bush thingy
nicky4tl
Hi,
I need to get two of the rubber and metal connector things that the bar which comes forward and up from the bottom of the lower wishbone connects to at the chassis. (so sorry i dont know the term for these. It is not the anti roll bar.) They bolt to the chassis with two bolts and the bar gets bolted to them at one end and to the bottom of the lower wishbone at the other. Local motor factors havent proved successful although QH still list the part.
I had a look at melun and wonder if these are them?
http://www.melun-retro-passion.com/...lling-direction-renault-r4-4l-id-863400N.html
They do look similar.
thanks
N
Certainly it is, here these tie rod bushes are called among R4 mechanics...well... like that, although we never specified bushy or not...!
Hi! haven't seen the whiff of a joint either-even tho' I've been to plenty of bars lately.... Hope all is good with you down in Athens Angel! -R.
