Bonjour from the South of England.
looks like a fun bit of kit.
Welcome to our little piece of the internet Micheal
Posted a comment on your message, not sure you can see it (I do not know how these profile posts work)
Here are more details
Gearbox
(EP) 80W90 GL3.
or
- (EP) 75W80 GL3.
Steering
80W90 or (better) 80W140 GL3.
Axles
(EP) 80W90 GL4 ou 5.
or
- (EP) 75W80 GL4 ou 5.
Engine
- if not "overhauled" : 20W50
- overhauled : 15W40.
Gearbox
(EP) 80W90 GL3.
or
- (EP) 75W80 GL3.
Steering
Axles
or
Engine
Wonderful information R2087...l've been looking all over the place for this...obviously not in the right places
Glad I could help
Let me know if you need anything else
Bonjour
Ummmh...l've been concerned about the axle oil...when l loosened (what l think is) the oil level plug (about a third up from the diff base) ...a paste/grease like substance slid out of the hole.
The rear axle has a short tube prodruding at 12 O'Clock.
The front axle appears to have a slotted screw in the same position.
Have you any thoughts/advice siv vu plac
look at my other post in the other section: you'll have all the answer on the link I gave you
if what is leaking is of the "coffee with milk" color, it is likely that it was water contaminated
Merci R2087...drained axles, gearbox and transferbox....good result from your friends blog and l found the translate button.
Will refill with fresh oil after Christmas.
Merry Christmas Everyone
