Hi All,
My R4 GTL is resting while other projects are getting finished off. I had a need this morning to open the bonnet. Having got in and pressed the rod release I didn't get the familiar clang when the catch releases. The rod can be pushed all the way forward but for some reason the bonnet won't release.
I've tried banging the bonnet above the catch with the palm of my hand and jiggling it about from side to side in the forlorn hope the catch might spring free, but no success. I wanted to open the bonnet as the battery is likely to be flat, hence I can't easily drive it and its currently wedged in the corner of a dusty shed.
Has anyone had the same problem, and a potential solution? Theres no obvious way of getting access that I can see (possibly from underneath but thats a pretty 'doing it blind' option), although as I recently had the bonnet off I'm toying with unbolting the hinges and lifting it at the front a bit to see if I can peek in and prod stuff with screwdrivers...
All suggestions welcome!
