John M
- Yorkshire
Having read "Frederick's" bottom ball joint replacement guide I decided to replace mine. There was no problem in removing the old ball joint and indeed I was fortunate to notice I could down load a pdf parts list. Great. I ordered the ball joints and tried to fit them. Oh no they didn't fit. I re read Fredrick's guide and noticed I am not the only one to get the wrong parts. I need ball joints with a measurement from body to end of taper of about 30 mm and the ones I ordered were 38mm. Not to worry I carefully checked and ordered again. Disaster! they came and were the wrong size again!
Has anyone come across this same problem? Do I risk ordering again? I have phoned parts suppliers and of course they just go on the numbers and whereas at one time it was easy to nip into the parts department and take a quick measurement nowadays that is not an option.
Has anyone got a part numbers for a LH and RH bottom ball joints with a measurement of body to end of taper of about 30mm?
Your help is much appreciated.
