M matt B Enthusiast Messages 10 Nov 4, 2007 #1 Hi again Does anyone have a drawing or PDF they can send me of the common carbs found on an 83 Van? Am trying to find a manual but no luck at the mo here in France! Ta
malcolm & Clementine the Cat Messages 4,599 Location Bedford UK Nov 4, 2007 #2 Which carb do you have? Most likely a zenith 28if? If you remove the air filter you should be able to see the model of carb stamped on the side. What is it you need to know about the carb?
M matt B Enthusiast Messages 10 Nov 7, 2007 #3 its a Zenith 281F V05 I took it apart but it appears no fuel is getting through from the float chamber! Cheers
