Changing suspension bushes
iMacThere4iAm
Tom Long
Morecambe
THe Haynes manual says that changing wishbone bushes is not practical and doesn't give any details as to why. Has anyone done this before?
I'm also having great difficulty identifying the correct bushes for my GTL. I have found the following Renault numbers:
Upper wishbone bushes (I think these are the same?):
77 00 104 152
77 02 111 568
Lower wishbone bushes (Maybe, although in the photo it looks too short?):
77 00 518 392
It's hard to cross-reference with Franzose and Melun because they don't include Renault part numbers in the catalogues.
The longer I spend looking at catalogues, the more confused I get. Help?! :confused:
MR 175 gives quite a lot of detail for this and it looks reasonably straightforwards for the upper arm, but for the lower, there is quite a lot of dismantling of associated suspension components and, of course, the torsion bar, which would be a significant item (see Malcolm's website) . It also recommends checking castor and camber settings post reassembly. This is awkward without the right tools. It would probably be worth changing the ball joints as well whilst everything is in pieces.
Thanks, I'll have a look at MR 175. I know the torsion bars are tricky, but my ride height is very wonky so there's another good reason to tackle the job. Likewise my camber is way off so that's another job that needs doing anyway. I have a full set of ball joints - those are quite simple to order!
Hi! This images were extracted from a post on Argentina Renault 4 Club Forum and were originally posted by user lord_dga and show a home made way to change those bushes with near to 0 tools.
(http://foror4.informe.com/viewtopic.php?t=3505)
Step 1 : Burn rubber bushes (avoid over heating cause it will weaken the metal parts)
Step 2 : Cut with a saw the internal metal bush
Advice : try not to cut too deep or you will harm the part.
Step 3 :Extract the internal bush using and old screw driver or any other metal tool and a hammer
This was the most sensible part you should be trully carefull not harming the part with the hammer.
Step 4: use sand paper to clean the part
Step 5 : Assembly the new bushes
To do this he used a large screw and a tube wrench as seen on the pictures
tubo 30mm = tube wrench 30 milimiters
Buje = Bush
Bulon M10 x 120mm = Screw 10 mm x 120 mm long
Before assembling the bush use some grease to make it easier
Finally the bush in position
Hope this will be helpfull.
And thanks to my local forum user lord_dga for the pictures and information!
P.D. : I know my English is not the best, but, hope you'll understand anyway
Regards
Matias
Hi Matias,
Thanks for your post, but the images don't work - I think you have to be a member of the Argentinian forum to see them. Can you download them and attach them to your post so we can see them?
Matias' approach is the much the same as I did, except my bushes were shot enough that I could simply push the inner sleeve and then peel the rubber out from the outer sleeve.
I simply used a long bolt through the bush and then through a suitable size socket as a screw press to remove the inner sleeve.
Pictures show the main steps.
I don't know why the Haynes manual is so scared of the upper bushes. They're straightforward to press out.
When pressing the new ones in, the distance between the two bushes needs to match the size of the carrier that goes between them. I suppose that's a bit obvious, but the number of times I've discovered the obvious after the event . . .
Geoff
Hi tom...
If you look for a seller on ebay called dataporo i get all my bushes from him...he gives the renault numbers as a referencr. I can have a look and send you a link on monday cos im in a camper for weekend..
On top of all of these, it's equally important that, when refitting the wishbones, their pivot pins are tightened when the suspension is at its datum position. Renault supplied a special tool for this (of course), but fortunately the job can be done without this.
Fit all suspension parts (do not tighten the wishbone pins fully yet) except for the torsion bar, and using a jack compress the suspension until the upper wishbone is slightly higher than parallel to the ground (5-10 degrees). Now you can tighten the wishbone pins to the specified torque.
