Clio crank sensor
cliohead
Im having trouble starting my clio because of a dodgy crank case sensor. Is this easy to replace or fix? Thanks for the help guys.
They are fairly easy to replace, just 2 bolts holding the sensor on. However access is awkward and if it's anything like my Megan Scenic you will need to disconnect a few pipes to get to it. I have just changed mine took about an hour and cost £35. (garage wanted £120)
