reidalpine
As I've noticed on several occasions the (front-doors) seems to develope a problem in the upper part (in-line with bottom of window-frame)
It seems to me that as time flies the upper-part of door is prone to develope an air-leak around door-frame.. Could be due to air being forced into the cabin by front-vent and as there is no Outlet the doors weak as they are ,will slowly be forced outwards...so air-leak and whistling-noise and draft rises..
having looked into this and checked a good few 4's
I've noticed a crack developing (seen by opening the door-
looking above lock and inline with lower end of window-frame) same goes for front-area of door above upper hinge....
All the cracks I've seen has been located in the exact same area...........
all seems due to door being forced outwards and so eventually breaking
Now- a plea to our Good Ambassador in Athens:
How about you have a look into this Angelos-and see if you can come up with a couple of nice formed "patches" for the affected ones of us to weld-in as a reinforcement and possible precaution on this weak-spot???
-as it's welded in on the "edge"of the door it can be nicely touched-up with some spray-box paint, so doesn't need resparaying of whole door if carefully
welded-in with wet-sponge etc. held in place while welding patch in.
-I,m sure there are more cracked members on here,and by keeping the work in-house so to speak,Agelos can keep busy in his work-shop, getting a fair profite ofcourse -plus keeping the rest of us happy campers
Other Most-Honourable R4Forum-members that have the need Please post here which will make it easier for Angel to see actual need and easier for us to twist his arm c",) -R.
