reidalpine
Hi all-Finally spring seems to be just round the corner in Norwayland-which as usual means there are things to be done that has been posponed all too long..
-Roffen is now at the garage where they will take out old 850cc engine complete with gearbox Then they will put in the 1289cc R5 mkI engine(R1225) and box (also 4-speed)so shouldn't be a big issue -I hope!
-I seem to have wrong info re.the new radiator w/fan I am to install further up front..as the R5 rad I got seem to be too wide. I thought this was the same rad used on the GTL ??
-Could anyone Please measure the Height and Width in cm.on the GTL-rad for me ?
PARTS URGENTLY NEEDED:
(1)The gear-lever support or brace,between inner-wings -as the old rad with the gearlever support-guide will be removed.(pt#77 00 523 432 in P.R 1006 pg.50.05)
(2)The two brackets to mount new rad in forward position
on two rubber-grommets.. Sits inside each side of front-framelegs..pt#77 00 652 793 & 77 00 652 791 pg.70.03
No rush as long as I can get them by last Friday
Thanx MUCH in advance guys/-R.
