After 18 months idle, when I came to start Pearl the battery was flat and finished. Fitted new battery, but the solenoid coil would not pull in. As the solenoid is near enough inaccessible, you can't see it let alone reach it, and on a LH drive car the steering column gets in the way too, I thought I would take off the inlet/exhaust manifold to improve access and promptly sheared a stud on the manifold to exhaust pipe join. So, as I had a top end overhaul kit, I decided to take the whole head off, overhaul the head and drill out the broken stud in the exhaust manifold.
With the head off found that the inlet/exhaust manifold had been fitted somewhat unevenly, being tighter at the top than the bottom; there was evidence of exhaust gas leaking by all along the bottom. And, I thought to myself, probably an air leak on the inlet side which would explain poor running, lack of power, and difficulty in getting the emissions right - even the Reno garage here in France had problems when they did it for the last CT (The French MOT). Promptly then sheared one bolt off on the rear water blanking plate and one on the water pump. All three sheared bolts/studs sorted OK, and the valves lapped in - they were in very good shape which I found surprising. Also surprising, the head face was dead flat - I expected some bowing but there was none at all. I refitted the water pump and the exhaust manifold whilst the head was on the bench; not only was it easier to do so but I could ensure that the manifold was on flat and true, much easier than doing it when in the car - that may have been the problem with the manifold the last time it was refitted.
The problem with the solenoid came down to just a dodgy connection - the spade on the solenoid that the wire from the ignition switch fits was very "dirty" - so much so that there was absolutely no continuity through it anywhere. Once cleaned up all was 100%.
So all boxed up again, and once the fuel starvation problem was sorted - (see the post "No fuel supply - pump, filter problem?") she started and ran OK.
So, a Question. Ran for 20 minutes as suggested by Mr Haynes in his excellent workshop manual, where it then says let it cool down for at least 2 1/2 hours and then slacken each head bolt in turn in the correct seaquince for 1/2 a turn then re-torque it again to the specified torque (and readjust all the tappets again). Now, is this correct? I cannot recall slackening cylinder head bolts half a turn and re-torqueing before, but it was a long time ago. I think all I ever did, (if I did anything), was to just check the head bolts were still to the specified torque. Reason for the question is that I am not sure of this slackening off 1/2 a turn bit.
What does the team think?
Chris
Chris
