kevinandkate
Sadly no longer an owner
Looking in the Haynes manual it appears there is a special tool needed to help remove the inner CV joints from the dif housing. Has anyone found a way round removing them without the tool. It appears to be a ring which goes around the CV joint with 2 rods leading back to a knurled wheel.
so there..lol
- the sparse add-on supplements are more fictional not factual.
I would'nt touch the driveshaft(s) until you've sussed out every other possible job needed requiring d/shaft/hub dissembly/drain g/box etc.
......................... I learned the hard way.
