Azazello
habitué
- Italy
Hello guys, I'm here asking for your help for my green lady freshly on the road.
A couple of days ago a friend during a meeting told me my brake lights were not working at all, and a few hours later the light alarm began beeping every time I pressed the brake pedal (I installed a box that sounds a beep every time I leave the lights on switching off the key, it has two wires linked behind the dashboard to 2 positive contacts, one is the +of the fuel level instruments and the other one I don't remember - I choosed a contacts that turns on switching the key and another that turns on switching on the lights).
Today I made a bit of testing, and turned out that every time the brake switch makes contact (I have the pressure switch on the master cylinder, but even taking off the wires and linking them together works) stop lights are not switching on but the first 2 lights on the dashboard (dynamo and temp/oil) and the fuel stop working. Disconnecting a wire from the cylinder switch makes the dashboard work again as expected, but I need stoplights too...
I will proceed escluding the "beeper" from the dashboard seeing if it is its fault, but in the mealwhile any hint or suggestion is really wellcome. As far as I know brake light wires are not passing through the dashboard...
Electric scheme is 1975 model.
