Hi to all the friendly R4 people,
since yesterday my good running R4 GTL has the flue.
During driving the dashboard bulbs are suddenly flashing.
Then the rear window heating bulb und the full beam bulb are on.
The Heating ventilator stops working and the direction indicator won´t work any more.
And now somthing strange. If the ignition is turned on the hazard warning flasher won´t work, only awfull sounds from the relay.
If the ignition is off everything works. Rest of the electric seems not to be infected.
I changed al the fuses to new ones... no effect. The fuse box looks brandnew no corrosion ....
Motor is starting and running, the rest of the car seems to be in good shape.
any idea ??
I appreciate every little help.
Greetings from Germany
Franz
any idea ??
Franz
