Engine capacity
Deauville
Can someone out there please help me work out the c.c. of our quatrelle (as they're called here in France) The French version of the V5 doesn't show c.c. or even b.h.p. (they work in 'fiscal power' here) and, as I'm using a Haynes manual for all the basic stuff, it would help to know the engine size; parts ordering isn't a problem as the French garages use the vin plate to identify parts but even that isn't foolproof and I wouild still like to know a bit more about it. It was first registered in Oct 92 and is a car (not the fourgon) and I have identified that it has the HAO gearbox but that still doesn't identify the engine c.c. - any pointers greatfully accepted. Thanks
I've also posted a version of this on Clementine's page
Donkey!!!!!
I've just done a search, followed the link and found out what I wanted - now why didn't I do that before instead of wasting everyones' time?! Still doesn't get me anywhere though as the Haynes manual doesn't cover my engine!
Oh well, thanks anyway
Welcome to the forum. So which one is it? I think the only choices were 956cc (Savanne) or 1108cc (Clan) in that sort of era. You can check the engine number to see which one is which, but there's not a lot of difference between the two (apart from capacity) so the Haynes manual should be OK.
The Haydes manuals didn't cover the 956 as it was never oficially imported into the UK.
Engine c.c.
Thanks Malcolm, it's a 112C - thus, apparently, a 956cc. You're probably right about the Haynes but, as it doesn't cover the 112C, there may be small discrepancies with some of the really technical stuff - if I get into trouble at least now I know where to start asking
Hi I don't know if this info could be helpful to you.
_____________________CC_______kW________CV
RENAULT - C1C 700____956_______30________41
RENAULT - C1C 706____956_______27________37
RENAULT - C1C 708____956_______25________34
RENAULT - 689 71_____956_______32________44
RENAULT - 689 710____956_______32________44
I have found it in a Valeo catalogue over the net.
Jon
