malcolm
& Clementine the Cat
- Bedford UK
I think I'm having a similar problem to ggcton. My Gordini is a bit flat at full throttle.
Previously I was having trouble with the distributor. I've replaced the smaller of the two advance springs with one from a spare R5G distributor and that's cured the problem with advancing at idle speeds which was making the idle speed difficult to control and requiring a great deal of advance to make the car work.
Now the advance can be set at factory settings, the idle is smoother, and advancing it a bit further will cause pinking, so it feels about right.
Now this full throttle thing - It's flat on full throttle regardless of whether I stamp my foot down or try to bring it in gently, and reducing the throttle slightly seems to improve things. The problem is much less severe now the distributor has been sorted, but it's still there.
I've had the carb off to blow out the jets several times. I'm thinking not enough advance or not enough fuel. But the car must have worked in the past so I'm not keen on just bodging it with a jet. Equally I feel I'm missing something. Ideas much appreciated.
