Engine Pulley Speed
ChrisH
I want to check my idle and other engine speeds using an optical tachometer. Unfortunately, I cannot get the reflective sensor to stick to the flywheel as it's too dirty, but I can get it to stick to the bottom pulley off the engine that drives the water pump and hence the alternator.
Does anyone know what speed that pulley will be going at? Presumably it is not at engine speed, or is it?
Be very pleased to hear if anyone knows the answer.
Chris
Agreed - the pulley right at the bottom that drives everything else is the camshaft which turns at half crankshaft speed.
