Hi
I have recently bought a Spanish import R4 which I cannot get to run properly. It starts and idles ok but will only accelerate if given a bit of choke, even when fully warmed up.
I have overhauled all ignition components and have good sparks.
I have good even compression (new head gasket) and no manifold or carb mount flange leaks.
Problem has to be the carb which is a 32mm Solex. (Engine is 1108cc 688 type year 1988)
My Haynes manual is very confusing regarding identification of the carb:
a) giving data in the supplement chapter for a Type 32 SE1A,
and b) showing an exploded view diagram labelled as a Type 32 EISA-4
and c) a component location diagram labelled as a Type 32 SEIA.
Anyway when cleaning the carb. I managed to damage the air compensating jet(ref c) above) which was very tight and half of the brass head to one side of the screwdriver slot broke away. This is a big jet which I now cannot get out but I can see down inside it so know it is not blocked. It actually seems to have an internal thread so it is possible there is a part missing?
Question is could the missing part or the broken off part of the screw head make such a massive difference to to cars performance?
And if so does anyone out there have a spare carb I could buy or try?
As a new subscriber to this forum I am looking foreward to a deluge of suggestions and offers to sort out my problem!!
Ben Courage
Ben Courage
