Hi gang,
My front disc brakes are (still) binding.
I’ve searched previous posts and it appears I may need to change the calliper piston seals. Before I take the callipers off (for the 3rd time) I want to check I haven’t missed anything….
Background to this sorry story…
My front brakes were binding badly (struggled to get out of 1st gear on the flat). So I thought it was a good time to change the old front discs and the pads.
After much persuasion I eventually got the discs off as per “tech tips”. I cleaned up all surfaces which the pad touches. Thoroughly cleaned the 2 sliding pins. And used copper grease etc.
The callipers needed to be pushed in using a g-clamp and a bit of wood. They were quite tight but not stuck.
I refitted and re-bled the system. Now the binding isn’t as bad but after a mile or so there is a hot brake smell. If you jack up the front the wheels still turn by hand, but there is significant resistance. If you wait 5 min it is back to normal. The rears are fine.
Is it normal to have both binding?
Are the Lucas rebuild kits on Der Franzose suitable for Girling?
http://www.franzose.de/en/Renault/R4...ttel/ANR84130/
Can anyone think of anything I have overlooked?
Many thanks for reading this far.
