Hi to all
I'm in need of some help again, The Front right disc brake is binding full on and is refusing to run free. The brake caliper is Girling. I have stripped the caliper appart and appear to have a binding slave piston. I have moved the piston in and out with the help of a 'G' clamp but it remains very hard to free up. I suspect that the piston has an 'O' ring that has gone oversize or something worse!! I am reluctant to remove the piston completely as with a knackered 'o' ring it may not be able to get back in.
I have tried to get a repair kit, or replacement 'O' ring without success to date. Has anyone had this problem and found a fix!! Knows the part number for the 'O' ring or can suggest a way forward.
The car is a Renault 4 GTL 1989
Thanks Steve
Thanks Steve
