Rutger-peer
The restoring Dutchman.
Hi there!
It's been a while since I've posted anything but just now I've ran into a problem I've not encountered before and which gives me just a slight headache:
I wanted to drain my fuel tank and therefore I wanted to unscrew the drain plug. Instead of the plug coming loose, the entire bushing that the plug screws into came off. Seems like it's pressed into the aluminium, but since it doesn't envelope the sheet metal of the tank and the fit is quite loose, I wonder whether it was originally glued tight or so.
Anyone had this problem before?
There's no flare on the sheet metal of the tank or on the bushing itself; it slides right out and in.
