lazyduck15
Hi, Need some help on a gear box.
I have installed an engine 1289cc and its gearbox from a R5, just recently. While swaping the gearbox handle I noticed lot of play on the upper shaft of the gear box along with, I guess, the 4Th (The one opposite to the engine) gear damaged by fast wearing due to the play. The bearing seems to be uncomplete, no balls et all (Was it balls type?).
The question would be if It is possible to replace the bearing just by opening the box from the side of the speedometer, extracting what is left from the bearing and replace for a new one. Do anybody knows the ID number for this bearing?.
On the other side, I am afraid I will have to replace the mentioned gear, as it is very damaged. Is it the same (Teeth qty, Diameter etc ) that is installed on the R4 gear box? Are they switcheable?
I will appreciate your comments
