Well, we were restoring a 1969 R4 until things went a bit wrong.
There was some work on the chassis, which was then sandblasted, and a good and reliable welder was sourced..
Only when picking up the chassis it seemed that Mr. Welder wasn't as experienced in welding sheet metal as he was in welding steel strucures I presume. Result, probably a familiar story, a very badly welded chassis and the project to halt for the moment (and some money thrown away !)
The chassis is torn quite bad, the sheets of metal are completely uneven, the sheet metal is only 1mm because of welding it too hot, the outriggers on the back are torn and completely unusable, a lot of sticky stuff is still hiding it's secrets..
Now it's quite difficult to restore the chassis because so much material is lost, even replacement panels don't fill the gaps anymore. Anyone an idea ?
A good welder is hard to find..
