mojobaby
I'm sure that this topic has been discussed before, but I can only find a 2008 thread.
Harbourseal has sent me a connecting rod and gudgeon pin, as my one is damaged, and I need to fit it to my piston.
The pin is obviously larger than the hole on the con rod, and its been in the deep freeze for a day, but it still doesn't fit. I know that the con rod should be heated as well to expand, but how much heat is needed and what is the procedure to fit it.
Is my only alternative to find someone with a press?
