Sprackers
- Tunbridge Wells England
Hi all.
Got just short of the pyrinees in the middle of knowhere and the clutch pedal went to the floor.
Limped back to campsite in 2nd and investigated.
Clutch cable freyed and stretched perhaps.
Problem:
Getting old one off:
I took the bolts off the rod end of the cable close to the gearbox.
I slipped it out of the holding bracket
NOW it got tricky.
I depressed the clutch pedal by hand (as per Haynes)
Expected to see the other end of the cable.
The top of the pedal doesnt come out far enough to see the bracket and the end of the cable.
I had to stick my fingers inside the hole at the top of the clutch pedal, almost cutting them off, and managed to feel the wire and where it went into the top of the pedal and just got the end of the cable free from the pedal.
OK so now its free.
I tried to pull it back through the bulkhead from inside the engine bay but it doesnt come through the hole.? the little block at the end of the cable, that I freed from the clutch pedal, Is too big to fit through the hole.
I tried to undo/unscrew/pull off the soft metal bit out from the metal bulkhead
I couldnt get it out without ripping/forcing it off. I dont want to do something I shouldnt so I stopped.
So how do I get the old cable out without cutting it?
Should that metal bit come out from the bulkhead?
If so how?
More to the point how onearth am I going to get the new cable back in?
PHOTOS:
1. End of the rod-end freed from bracket I have taken the nuts off.
2. Cable lying left to right see end going into bulkhead on right.
3. Problem: you see I have tried tentively to get the metal housing out but cant.
4. The clutch pedal in normal position
5. The clutch pedal fully depressed. See, I cant see the end of the cable to remove or replace, (although I have managed to remove it somehow)
Cheers
Sprackers - Stuck in campsite in France.
Problem:
NOW it got tricky.
OK so now its free.
If so how?
PHOTOS:
Cheers
