Head gasket change
Mike seaward
Norfolk
Hi everyone, hope you are keeping safe.
Just about to do a head gasket on my 1126 (839 A) 782 cc engine
Anything to look out for on this model engine. Runs really well after a lot of work but now the oil is getting milky so got to bite the bullet and sort it!
Mike
If you want to take the head of do it in an upright turning motion to make sure that the cilinder liners don’t move.
after the head and gasket are off secure the liners. If they come loose you need to get new liner seals as well.
Replacing the head gasket is a straight forward job. Good luck.
once you've worked out the trick to undo centre head bolts
