i've found out why i got clouds of steam from the facia vents after a few minutes driving on my '67 TL....stripped out heater and vent hose was perished... iwill be changing the short main hoses also which sit hidden behind the matrix
is it worth renewing or rebuilding the heater valve, or even just fitting an elbow with no valve mechanism (to stop any future leaks in the valve)
i was surprised how inneffective the flap which "stops" the air going upto the facia is: it hardly shuts off any air flow
the lower flap appears to have at least a 5mm gap all round it: anyone fitted some sort of rubber seal to close off this gap, and force more air upto the screen?
the ducts are quite poorly sealed to the facia outlets, meaning the screen gets even less air
main heater hose seems to be 18mm...is this right?
also, is fuel hose ok to use for heater vent hose?
any thoughts gratefully received....ade
