Greeney in France
Bloody nice bloke actualy
On my 1986 La Poste F4 with disc brakes...
I have just taken apart all the front wheel gubbins to do new bearings, ball joints and steering gaiter, track rod ends and new shocks.
Is there a sequence to put it all back together? as I did so on one side having renewed all I wanted (even the bearing job went smoothly) but when I was going to fit the new shock the suspension seemed unusually solid have I locked something up?
On the same side the drive shaft slipped out of the gearbox but I just pushed it back in again have I done something or is it normal?
The reason I thought it stiff was that I tried to put a jack under the bottom ball joint to move arms up to remove shock but it lifted the car??
is this confusing
Thank you for your help
is this confusing
