Help with wiring loom
Hugo Nunes
Abrantes, Portugal
Hello, I'm helping a friend with the restoration of a 1986 renault 4 gtl and now we are facing some problems with the wiring... The lights at the dash panel doesn't light up... Neither the battery or the parking brake...none of them... Can anyone send me the wiring diagram of it? my e-mail is hugogoncalonunes@gmail.com
Thanks in advance...
Hugo
have sent you a wiring diagram via your e-mail address
Regards
Tom
On a GTL there is a flexible circuit board that has a number of push fit multi pin connectors . These can be troublesome. My guess a bit of fiddling and cleaning of these connectors will solve your problem
Sorry should have said...circuit board is behind dash lights and speedo
Could just be dirty fuses have you checked for voltage both sides of each fuse
Many r4 have turned up after customer has checked fuses and says they look ok
