Had to replace fuel pump on my TL and I'm worried a little fuel may have contaminated the oil, the car is running well when cool but tends to overheat when being driven for a few minutes above 90 kmh, I say overheat, the light comes on but it seems to soldier on happily enough. The hotter it gets the faster tickover becomes so I'm guessing an oilchange would possibly cure it but the oil doesn't smell of petrol. I've drained and refilled the rad and bled it (I presume the hose hanging out of the bulkhead is the bleed valve) which hasn't really helped. It's 30 degrees plus every day at the moment here so it's a bit of a worry. Any other thoughts?
As an aside the hot/cold switch slips so I can't put the heater on to blow the excess heat out. I'm going to pull it apart tomorrow but I thought someone might have some handy hints.
Cheers all
Cheers all
