Hi R4 friends,
I just dismounted the front drum brakes on my 850 cc. I removed brake shoes and their springs, handbrake cables and hoses, however I can´t loose the brake cylinder screws, because they are hardly reachable. There is a special spanner needed? I should remove the backing plates also, because the eccentrics are immovable. So I pushed the shaft back and released the four nuts on rear backplate side, but I can´t find a way, how to remove the hub and backing plate.
So please can you advise me, how to do that?
Greetings from cold Prague
Pavel
Pavel
