reidalpine
as I haven't anything (more) sensible to do I've gone haywire with soundproofing Roffen for our Lonely High Nordic Challenge.
sound and noise are a funny thing-like a Granny yapping on and on and on 'till you just don't notice it anymore-untill you wake up one morning finding you have killed her in your sleep :eek:
as i didn't want to change the look and feel of an otherwise original interior I opted for large sheets of rubber-cork (doped)
same material you would use for making cork-seals.This material won't hold or trap water.smells lovely and comes in sheets of 50x50cm or 100x50cm in 0,5/1,0/1,5/2,0/2,5/and 3,0mm thickness.
I didn't want to cover the actual profiles themselves so opted to cover only the flat panels in the roof plus sides and rear side-parts plus rear-door Some 75-80% of all inside panels covered and Boy! does it make a difference....
I thought Roffen was fairly quiet,but noticed this buzz after driving a couple hours-why I often use earplugs..
Anyhoo;
Any/All resonances and noises from vibrating body-parts (No-not mine!) are now dampened to an extent I did not believe possible..
-In addition to this for the inside of the fire-wall/bulk-head I used what is called Shoddy -that's ripped fabrics lightly compressed to 1cm thickness. comes in 100x200cm for 10£ Only top-part of it is lightly glued to as high under the dashboard I could get and mat stretches to profile right under front-seats .glued only top of it so as to have the poss to lift it up and check for moisture/water under it.
Last place (but Most important place for killing direct noise!)
I soundproofed the engine-side of the fire-wall/bulk-head.
I did only the Mid-section right behind the timing-chain which sits real close to the fire-wall and there is nothing to dampen the noise from it as heater-matrix sits right on the inside.
used thin cardboard as template (Malcolm-way) cut very precisely and made holes for heater-hose air-bleed-valve plus the gully-hose. Used 1,5cm thick stuff approved for engine-rooms in boats,all fireproof and safe.this stuff has glue already on one side-A tip here! if you want it to look nice and slick-squirt water on firewall where glue goes then it won't stick where you don't want it -and you just sliiide it into position -soon as water evaporates it sticks like ..Well glue.
-I'll try to take some piccies tomorrow -just plainly forgot it today as the contact-glue I used inside is some Real Good Shit and I had a High-noon all by my self in there.
-Talk about Purple Haze!
Contact-glue on metal-panels works nice and has an extra advantage if you ever want to remove these sheets as it comes off nicely in one piece and leaves no trace at all..... Oh well-Time for a Newcastle brown and some kip later.. -R.
Anyhoo;
