hi having real problems starting despite new plugs,123 ignition cleaned carb so could the problem be the ignition leads?if so where do I get some from please,any other ideas?fuel seems to be getting through,perhapsflooding
Hi Brian,
Before you installed all of the above? Was your engine running ok?
Than start eliminating things
Do you have a spark yes or no if no it's an electrical problem.
If yes it might be the firing order or the position of the rotor.
It might be a weak spark to. Have you changed the ignition coil as is the advice of 123 to also change it with all the leads and spark plugs
Do you have petrol in your carburetor and is it getting to the cylinders.
Try and work your way through al these questions.
