ecurb.renots
- English but live in France 87250
I have an interesting little problem which i think is probably a faulty indicator relay but i am not certain. The car is an 83 model GTL which has 4 connections on the flasher relay not 3 as per earlier 4's. However it has a 3 pin relay fitted ever since my ownership which works but has always flashed too quickly. It now has developed a new feature in that it flashes the dashboard indicator lamp perfectly on tickover but at any engine speed over that the light stays on and does not blink when the indicators are applied, the actual indicators still flash but barely almost show a constant amber light.
Any thoughts and if it is the flasher unit which should i purchase to just plug and work without any rewiring. I tried a more recent 3 pin flasher but that did absolutely nothing so i suspect they are not quite universal.
Many thanks, Ecurb
Many thanks, Ecurb
