berserk_gorilla
- Newcastle upon Tyne
My indicator is on the blink. Does anyone know what could be the cause please?
Bluebell has been running brilliantly ever since Bobble replaced the condenser. In the last two weeks though the indicator has decided to go on the blink.
It started when I was on my way to work. Everything had been working well. I came to another junction and the indicator didn't work, instead the dashboard lights went crazy. I turned the engine off and on again and all was sorted. Later that journey the same thing happened again however it did not rectify itself on restarting the engine and hasn't worked since.
Signs and symptoms:
> Car starts and runs perfectly.
> Lights work (full, dip and side).
> The heater works but on the dash the fog light and high beam lights come on half bright.
> The radio no longer turns on.
> When the car is not running, hazards work perfectly.
> When the ignition is turned to the first position, hazards and indicators work perfectly.
> When the ignition is turned to the second position or the car is started neither the hazards or the ignition work.
> Turning the hazards on causes all indicator lights to come on and stay on, this is associated with a 'buzzing noise'.
> Indicating causes the side chosen to come on and stay on, this is associated with a 'buzzing noise'.
> When turning the hazards and indicators on here the dash fog light and high beam lights come on half bright.
> Returning the indicator to neutral and turning dip beams on and off seems to reset the problem.
Current management:
> Inspected the fuses, all intact.
> Inspected the indicator relay, makes a 'buzzing' noise when the engine is running and the indicator is tried.
> Cleaned and re-earthed the main earth at the front of the right inner wing.
> Taken the dash off to look for loose connections / water, all seems connected and dry.
N.B. There is a leak, this is either coming through somewhere at the top of the A panel on the right hand side or possibly along with the choke cable (grommet missing, now replaced). This has caused a puddle in the drivers side 'glove space'. All wiring and cables appear dry and dusty (undisturbed for many years...).
Does anyone have any ideas about what could be causing Bluebells problems? She's sitting in the back garden wishing I was clever enough to fix her. Any advice would be great. Below is a video demonstrating the problem.
Thanks,
Ben
Signs and symptoms:
Current management:
Thanks,
Ben
