Juddering in 4th below 70kmph
DEREK SLINGSBY
Central France
Can anyone please advise? My 1992 R4 GTL judders bad when below 70kmph. I can remove both 1 & 2 leads off the dist cap at he same time and the tick over doesn't change, remove 3 or 4 and it stalls. The leads are ok, the plugs are new, new air filter, dist cap. I'm at a loss, I've even set the valve clearances, those on 1 & 2 were very small.
Are the leads on the right plugs?
Sounds like neither 1 or 2 are pulling their weight.
Try swapping - just to see...
1,3,4,2, 2 is at the front of the cap. I have tried the cable off 4 on 1 and 2 but whatever is tried 1 & 2 are always non existent, 3 and 4 always good.
I think it's time for a compression test.
You've already done all the other obvious things.
Other possible issues would affect all cylinders.
The low valve clearance hints at valve seat recession, though I'd expect resetting the clearance to have made some difference.
