Stuart Delahoy
            Hi Linda, jjad is right, the part of the chassis where the rear suspension is mounted is very prone to rusting, and of done properly is very time consuming, so the cost of this repair is high. If it has been done right that's great, so do try to check it out. This car is think is a 1977 model with the single amber indicators at the front and side-lights in the headlights. So I'm thinking now that the grille is wrong, and should be the aluminium type. Oh dear, I've got my nerd had on, please excuse me
Can you find out who did the repair work? The seller might have pictures of what was done, or could provide an exact description of what was fixed (e.g. inner suspension mounts, outer suspension mounts). Where is it located? If you do go to view it, see if you can look underneath. Check that there isn't uneven wear on each side of each of the rear tyres (indicative of misaligned rear wheels).
Linda, might be worth asking Paul Cunningham to have a look at it as he's local and knows them inside out. Think he is in Worthing.
He's on here as Mr Reno 139 or something similar but googling him should bring up his contact details.
(It was featured in Classics Monthly in a Reader's Cars feature in February 2016. It belonged to someone called Adrian Williams. Apparently recorded in the article as no history, but in exceptional original condition, with only a few minor bubbles here and there).
It was presumably sold on by Mr Williams after the Classics Monthly item, since it is now listed as being down in Lewes, and was previously photographed by CM for the article in Derby. However the article is a winter one and the pictures are clearly summer (leaves on trees) so were I would suggest, taken several months earlier in 2015. The 2016 article says that the owner had received no history with the car but that it appeared in excellent condition. The current seller says 'Extensive welding work carried out underneath around rear suspension, very high quality work.' but doesn't necessarily claim to have done it himself. The CM article claims that when on the ramp for its last MOT it was remarkable how clean and rust free the underbody was, so a few possible contradictions there.
The current seller also has a Triumph for sale and various bits of motobilia. He claims to have re-commissioned the car, although CM obviously drove it and pronounced it in good shape in 2015, so where it has been in the interim would need questioning.
Hi
That's really useful to know. I'm going to contact the seller to try to get a bit more background to the car.
It's still going for £3200 on ebay but bidding has a way to go yet. Suspect it may go beyond my budget - do the older ones usually go for more if they are in good condition?
I'm just new to all this trying to get to grips with what I can expect/ find without buying a heap of trouble!
Linda
Linda
These cars are now getting on in years and therefore appeal to the DIY enthusiast. As things go wrong, and they will, unless you are prepared to learn and do things for yourself, or have a mechanically inclined boyfriend/husband/partner/father, then you're going to have to search for a sympathetic mechanic local to you, many of which must be charging £65 an hour or thereabouts. So Sussex Sports Cars WERE encouraging you, but encouraging you to think things over with your head rather than your heart.
