Hi again, I am having trouble with my brake lines.
I have just replaced all of the brake pipes on my R4 "Savanne".
When I connected my Easybleed kit, fluid started to drip out of several of the joins! I have made these lines my self with a fairly good quality flaring tool, the ends looked quite good and I am certain I have the correct fittings and flare type.
How tight should they be done up? It gets to a point when you are just squashing the copper flare and I'm not sure if I should carry on. Also do you ever use a plumbing type sealant on the treads?
Any help much appreicated.
Tim
Tim
