Hi,
I bought a renault 4 850cc a while back.
I think I might need a new starter, it got really hot one day because I forgot the ignition on,and started smoking.
I need the following parts:
Clutch kit
Sparkplug cables, with their connector plates
Head gasket
Piston rings
Rubber plug for bottom of petrol tank.
I want to redo the engine and replace the clutch, can someone please explain how I should do this, and where I could order all the parts mentioned above, even if secondhand?
I'm from South Africa.
I already read the instructions on this website, but they do not give enough details.
This is the first time I am going to work on a car,by the way.
Oh and the copper fuel pipe between engine and tank is clogged as well, how do I clean it?
Thanks.
Clutch kit
Head gasket
Piston rings
Thanks.
