Hi. Having tinkered, cleaned and replaced filters and plugs under my out of storage R4 GTL, a new battery in place and with great anticipation I put some petrol in and turned it over. It had previously jump started when needed every now and again in storage, but now, nothing!
I disconnected the fuel line and found nothing was being pumped. So, is it the pump, which I would be surprised if it was as it had started in the past, or is it possible that rust in the tank has been dislodged and sent around the fuel line and blocked it or the pump? Why should I do from here? I tend to think that it might be the pump as not even a trace of fuel comes out on turning it over, but it it strange when this has worked in the (not recent) past.
If I need to get a pump, can this be sourced from any motor factors??
Thanks for any experienced advice..
Jon
Jon
