parts needed for gerrard
gerrard
:oops: My 84 R4 is in need of some parts, could anyone help i need n/s track rod end o/s top+lower swivel, also two front discs and 2cylinder and 4 shoes for the rear. cheers sandy
These are all available from your local Renault dealer. However, to save some money, try your local Motor Factor first.
The rear brakes were either Girling or DBA - you'll need to check the make before ordering. If you fit front discs, always fit new pads at the same time. Front calipers can either be DBA or Girling, but they are usually the latter.
If you buy your rear shoes from a Motor Factor, buy the fitting kit from Renault as pattern shoes rarely come with the kit.
Steve
You could also try eBay for the balljoints. You can normally pick them up for between £5 and £10 each. I'm reluctant to buy brakes from eBay.
