i replaced the cyl head gasket on my '67 850 TL, after skimming head etc.
I have not been able to get it started since.
I've changed the leads, points, rotor arm, condenser, coil, timed it no. 1 at 10mm before mark on flywheel, not a chance of starting.
Distributor can only go in one way (Ducellier), leads assembled 1-3-4-2 clockwise.
I've got fuel and a spark.
Compression, cold (obviously), is 130 (no.1 nearest gearbox), 150, 140, 132 psi.
These are low, i think, but maybe a hot engine increases these figures?
What is worrying, is that cylinders 3 and 4 show oily deposits on the plugs.
When i try starting, it coughs and splutters, then it let out an almighty bang.
I retired, hurt.
Any crumbs of advice or statements of the bleeding obvious appreciated....Adrian
I retired, hurt.
