STEPHEN ADDISON
- THIRSK, NORTH YORKSHIRE
Morning all --- I have been looking through past posts regarding the front torsion bars but i have not found an answer to my current problem. My chassis and suspension have been completely stripped down to the last nut and bolt and everything has been re welded, restored and re assembled with the exception of the front torsion bars which where removed cleaned painted and greased. they have now been fitted again but i must be doing something wrong as i am unable to achieve the 41 mm setting distance from wheel center to under side of chassis as quoted in the Haynes manual.
The facts are
A) The body and chassis are together with engine and box fitted but has no wings, doors, tail gate, bonnet, glass or interior.
B) The torsion bars are fitted into the front lower suspension arms
C) The rear of the torsion bar were bolted in position following the procedure listed below
D) All other elements of the front suspension were fitted prior to operation C)
The situation is that with the car fully jacked off the ground so that the wheels and tyre's are hanging in mid air i then aligned the rear torsion bar in the bracket and bolted it via the 3 bolts to the chassis -- all quite simple but in lowering the car from the jack it settled almost at floor level ( fully closed shock height ) which is no where close to the suggested 41 mm setting and it is far from full weight
In my mind this was the maximum torque i could impart onto the bar and having checked the height i was going to adjust it down by lowering the car on the jack and bolting again until the height was correct
What am i doing wrong, should this procedure be carried out without some elements of the front suspension assembled such as the shock in order to increase the amount of travel that the lower arm can take thus increase the twist on the torsion bar ? or is it more complex
Steve
The facts are
Steve
