reidalpine
Hi all!Finally have managed to get the R5engine/box home.
washed and cleaned it out and found it to be engine-type: 810 G - 726 (1289cc) my book says 44Bhp(?)
8,5:1 comp. Carb:Solex 32 SEIA or is that SE1A..
-Why oh why couldn't it have been the 64Bhp??
:wink:
-What does it take to get some more hp out of this one? Headers?less restrictive exhaust? other carb? Nitro? c",)
potato-Chip tuning??
gearbox :
354 -136 4speed(floor-shift)
but should be only matter of changing top-lid to get Proper shift right?
-Will the crossmember from a 4L fit Roffen the F4 (LHD)(2106)-or should I rather have a 'proper'strut-brace made up? it's mostly for supporting the gear-lever...
Have all motor/gbox mountings ,did I hear something about mountings on FRAMEside had different angle ??
also have driveaxles and compl.front-hubs w.discs/calipers (just in case I need to change for discs later on)
-will give it a try as is first
as more or less given up locating mech.calipers from older Suzuki 50cc to use as handbrake on discs.. (I have one but need one more Hint-hint...)
WANTLIST: Reardoor L or R-hinged to fit R4F48 fourgon.
Prefer complete with window and as rust and dentfree as poss..... -R.
:wink:-What does it take to get some more hp out of this one? Headers?less restrictive exhaust? other carb? Nitro? c",)
gearbox :
