Hi,
Is the Renault 6 engine, 688-A-7-10 exactly the same as a Renault 4 engine (eg like 688-C-7-11 fitted to F6 van or any other R4 688)?
It looks the same as I think from other posts that the R6 is same as R4 underneath the shell, but I need a second opinion.
Reason - I scrutineer at a grass track type event (in Gorges, Normandy) and basically I want all cars to be use engines from the Renault 4 range -Renault 5 engines definitely excluded.
But I've got a driver with a R6 engine above, and all the tech stats I can find seem to be the same between the two example above
eg 70mm * 72mm, ratio 8.3, capacity 1108cc - and R6's were produced during the life of the R4.
Thanks for all input
Ant
Ant
